Disable (some) FLIP Particles
ParticleSkull
Hey guys,
Is there a simple way to disable some particles from the simulation like i'd do with RBD?
I have a set of particles inside a group and I need them to be stopped at same position but still interacting with the other particles. Does it makes sense? The group is animated
I tried setting v=0 but it doesnt work as expected. I did another trick inside a sop solver to get the position from the previews frame so it stays static but then I cant use the resample.
Im just wondering if theres a a simple way like like an attribute the would make them sleep.
Cheers,
Alvaro
