is SDF and VDB are same...? if not what is the difference between them?
Basically VDB is a container, SDF is a certain type of information (distance to surface, with negative numbers for being "behind" the surface).
SDF can be hold inside a VDB, but also inside a "classical" Volume.
So, no it's not the same.
The Link from Milad Savar is a good starting point.
