anicg Posted October 29, 2019 Share Posted October 29, 2019 (edited) Houdini, the mother of proceduralism, expects colour values to be set manually in the ramp parameter. Right? i came across a feature in substance designer in gradient map called “pick gradient” that samples colour values from any part of an image you select with colour picker and it automatically populates the ramp/gradient with all the values it found. It gives a rich ramp. Don’t like the ramp values? Just click a different area, you get a different ramp (colours). Like the colours but not the ramp distribution? Just move a few colours around. This is procedural. is there in Houdini (rightfully expected from a procedural software) a way to do something similar? At least not create colour by colour. Edited October 29, 2019 by anicg Quote Link to comment Share on other sites More sharing options...
vtrvtr Posted October 29, 2019 Share Posted October 29, 2019 If you're asking "is there a button that does this?", then the answer is almost. If you're asking, "can I do this?", then the answer is yes. There's no button, but in the color editor you can load an image and pick colors from it, so you can do a gradient based on the image in a few clicks. If you want to do it in one click, it's relative simple to sample image colors. You can take inspiration (or use it directly) something like this https://github.com/fengsp/color-thief-py Quote Link to comment Share on other sites More sharing options...
anicg Posted October 29, 2019 Author Share Posted October 29, 2019 Thanks. I think the colour thief creates a colour palete. But the main point is to have Houdini ramp parameter populated by these colours. Making a colour palette is dead easy, it can be done in color.adobe.com, or even faster in Davinci resolve. It’s not about the colour palette, it’s about populating the ramp parameter in Houdini, and being able to change one’s mind and repopulate it within a couple of seconds with another palette. If i use 7 colours (sometimes it can be 34 or more) i don’t want to waste time selecting each triangle in the ramp, click on the colour picker set one colour, and repeat it again, and again and again even of I’m selecting from a colour palette. i don’t know python, and i don’t think i will learn it fast enough to code this myself. Quote Link to comment Share on other sites More sharing options...
Dweeble Posted October 29, 2019 Share Posted October 29, 2019 (edited) If you google "Techie Houdini", it's a .se site with a few Houdini tools. There's a 'Color Sampler 2.0' HDA that populates a ramp based on an input image. Has a ton of settings as well including samples, distribution of samples etc. It's a free download but there are also a few paid ones on there and I'm not sure how frowned-upon linking to such things is. If I recall Substance Designer has the line-painting mechanic? The HDA has a 'line mode' but as far as I can tell that just does the straight line. Doesn't look like modifying it to accept Draw Curve would take much work, though. Edited October 29, 2019 by Dweeble 1 Quote Link to comment Share on other sites More sharing options...
anicg Posted October 29, 2019 Author Share Posted October 29, 2019 (edited) Thanks. the color sampler 2 does create a ramp but: - it seems like it keeps it for itself, no idea how to make houdini ramp parameter get those colours. - it’s only in SOPs, not in COPs. Do you know how to get those colours out of it and into the ramp parameter? (i have a ramp parameter inside a vopcop2gen in cops). Edited October 29, 2019 by anicg Quote Link to comment Share on other sites More sharing options...
flcc Posted October 29, 2019 Share Posted October 29, 2019 (edited) You can use the "techi color sampler" to sample the picture, then copy paste the result ramp on a standard houdini ramp. Not really procedural but just two clicks. Edited October 29, 2019 by flcc Quote Link to comment Share on other sites More sharing options...
anicg Posted October 29, 2019 Author Share Posted October 29, 2019 Many thanks. I could link them with the usual “copy parameter” and “paste relative reference”. Now when i load a new image, both techie color sampler and houdini ramp parameter get updated. That’s what i was looking for, one click. Many thanks. Quote Link to comment Share on other sites More sharing options...
snoot Posted December 25, 2020 Share Posted December 25, 2020 Hey there, I built a tool very similar to the Substance functionality. You can draw a line on a image and it turns it into a ramp parameter. https://richardcthomas.com/image-to-ramp Hope it proves useful! 3 2 Quote Link to comment Share on other sites More sharing options...
Alexandre Posted September 25, 2024 Share Posted September 25, 2024 the download boutton send to sidefxlabs tools github page but I can't find the "imagetoramp" sop into labs nodes, is it normal ? thanks Quote Link to comment Share on other sites More sharing options...
