monomind Posted November 1, 2019 Share Posted November 1, 2019 I'm having this problem with houdini volumes. In previous versions of houdini, when I created a volume, it used to show the outlines of the volume object (wireframe box) - but I see that's missing in my Houdini 17.5.391 However, When I enable "Two Dimensional" it becomes the wireframe outline of the volume becomes visible again. Here are two screenshots. I wanted to ask this because I'm wondering if there is a setting to turn this on by default? Quote Link to comment Share on other sites More sharing options...
3dome Posted November 1, 2019 Share Posted November 1, 2019 hmm I guess it's guide geometry (like when you create an otl and can spcifiy a node as guide geo, just here it's code in c++) and maybe it's a small bug in the code. anyway, if you need to see it you could put down a volumevisualize SOP as a workaround Quote Link to comment Share on other sites More sharing options...
monomind Posted November 1, 2019 Author Share Posted November 1, 2019 (edited) How does yours work? (Wondering if a reinstall would fix the issue) Edited November 1, 2019 by monomind Quote Link to comment Share on other sites More sharing options...
monomind Posted November 1, 2019 Author Share Posted November 1, 2019 Just installed the latest version (17.5.425) - same behavior. Quote Link to comment Share on other sites More sharing options...
monomind Posted November 3, 2019 Author Share Posted November 3, 2019 Bump: Can anyone comment to this? I'm looking for a solution, is this the expected behavior (does your houdini work the same way?) Quote Link to comment Share on other sites More sharing options...
Atom Posted November 3, 2019 Share Posted November 3, 2019 Have you added any density to your empty volume? Volumes also don't show up, if you are in wireframe mode. Quote Link to comment Share on other sites More sharing options...
