Mizunori Posted November 5, 2019 Share Posted November 5, 2019 Please help me. I just started studying Houdini. I don't understand now. It's about viscosity. It is in the red frame of the image below. I created a mesh with flip, but it is not smooth. How can I make this part smooth without bumping it? (I using houdini17.5) Quote Link to comment Share on other sites More sharing options...
DonRomano Posted November 5, 2019 Share Posted November 5, 2019 Maybe enable smooth in the particle fluid surface node and play with it ? Or you can create your own meshing system and use vdb smooth sdf , and also play with the adaptivity threshold ! Cheers, Quote Link to comment Share on other sites More sharing options...
Mizunori Posted November 5, 2019 Author Share Posted November 5, 2019 30 minutes ago, DonRomano said: Maybe enable smooth in the particle fluid surface node and play with it ? Or you can create your own meshing system and use vdb smooth sdf , and also play with the adaptivity threshold ! Cheers, Thank you very much for you comments. The mesh is created particles. It was improved if the number of polygons was increased from the time of the image, but there was another problem. That is, the mesh breaks along the way. I want to manage this and get connected. It may be dirty as data,but keep the hip file. If possible, please give me advice. I'm sorry if my English is difficult to communicate... Chocolate_cake_v03.hipnc cake.obj Quote Link to comment Share on other sites More sharing options...
Atom Posted November 5, 2019 Share Posted November 5, 2019 (edited) Try setting Particle Motion/ Reseeding/ Surface Oversampling = 36. Edited November 5, 2019 by Atom Quote Link to comment Share on other sites More sharing options...
Mizunori Posted November 6, 2019 Author Share Posted November 6, 2019 16 hours ago, Atom said: Try setting Particle Motion/ Reseeding/ Surface Oversampling = 36. It's amazing. The result was as expected. Thank you very much. I never thought it would change with one parameter. Let's example Flip solver again. I would like to send Mr.Atom the greatest thanks. Quote Link to comment Share on other sites More sharing options...
