stu Posted August 9, 2006 Share Posted August 9, 2006 Because we all know that what the world needs is another CG teapot. Wireframe Occlusion Final Render Here's the SOP network for the model, and I apologize for the mess in advance. teapot.zip If it doesn't work, let me know and I'll fix it. Quote Link to comment Share on other sites More sharing options...
altbighead Posted August 9, 2006 Share Posted August 9, 2006 HI Stu , Very nice and clean model,pluse sexy rendering !! It is about time you should xconsider creating learning dvd for houdini . Something like lighting/rendering techniques for Houdini. Cheers.! Quote Link to comment Share on other sites More sharing options...
edward Posted August 9, 2006 Share Posted August 9, 2006 A bit late for the SIGGRAPH 2006 Teapot Exhibition though. I like it nonetheless. Quote Link to comment Share on other sites More sharing options...
ciappo Posted August 9, 2006 Share Posted August 9, 2006 As long they're so nice the world do needs teapots. I love this kind of model/render, so clean, so tidy. It makes me feel like everything it's in his own place. Love it. Quote Link to comment Share on other sites More sharing options...
zoki Posted August 9, 2006 Share Posted August 9, 2006 very nice work! Simple but effective thanks for sharing z Quote Link to comment Share on other sites More sharing options...
lisux Posted August 9, 2006 Share Posted August 9, 2006 Great render stu, and very clean model. Can you tell what SHOPs have you used for the teapot? Quote Link to comment Share on other sites More sharing options...
stu Posted August 9, 2006 Author Share Posted August 9, 2006 Great render stu, and very clean model.Can you tell what SHOPs have you used for the teapot? The SHOPs are custom VOPs, not because they're doing anything fancy, but just because it was convenient. One of the things that I didn't do but meant to was to vary the blur in the environment map in order to represent the different distances between the ground, trees, and sky, etc. from the pot itself. I think that a vertical change in the blur value across the map would have been good enough to pull off the illusion in this case. If I get a chance, I'll crank aout a new render. Thanks all for the comments - if you see anything that could have been done better, please do so and post it here. Quote Link to comment Share on other sites More sharing options...
SpencerL Posted August 9, 2006 Share Posted August 9, 2006 stu, I think it looks really good. The model is perfect. The only things that I suggest changing is that the handle material looks "CG". It has a very rubbery feel to it. I think its needs a little spec/reflection added. Also I think the shadow being cast is not dark enough, but its hard to tell since the teapot is not in an environment. Otherwise I think its great! Nice work! Quote Link to comment Share on other sites More sharing options...
lisux Posted August 10, 2006 Share Posted August 10, 2006 The SHOPs are custom VOPs, not because they're doing anything fancy, but just because it was convenient. One of the things that I didn't do but meant to was to vary the blur in the environment map in order to represent the different distances between the ground, trees, and sky, etc. from the pot itself. I think that a vertical change in the blur value across the map would have been good enough to pull off the illusion in this case. If I get a chance, I'll crank aout a new render.Thanks all for the comments - if you see anything that could have been done better, please do so and post it here. So is the standard metal lighting model with anisotropic speculars and an environment map? Quote Link to comment Share on other sites More sharing options...
Visual Cortex Lab Posted August 10, 2006 Share Posted August 10, 2006 STu.. as always... awesome work .. i love you clean modeling.. and your easy-but-effective shading... congrats. cheers Quote Link to comment Share on other sites More sharing options...
MatrixNAN Posted August 10, 2006 Share Posted August 10, 2006 Hey Stu, Nice clean model man. Also the render passes look awesome great work. Looks very real. Cheers, Nate Nesler Quote Link to comment Share on other sites More sharing options...
LEO-oo- Posted August 10, 2006 Share Posted August 10, 2006 Nice! Clean model - Stu great job! Quote Link to comment Share on other sites More sharing options...
meshsmooth Posted August 11, 2006 Share Posted August 11, 2006 well it is more of a kettle than a teapot is'nt it Quote Link to comment Share on other sites More sharing options...
Dhiren Posted August 12, 2006 Share Posted August 12, 2006 Very neat model Stu,awesome rendering.Looks damn nice. Good job.Keep it coming. Cheers. Quote Link to comment Share on other sites More sharing options...
