Limit total smoke
art3mis
Jim, if I get it right, you should accumulate the amount emitted at each frame. In SOP you can use a volume reduce and set it to "sum": this way you know the density (for example) emitted in that particular frame. Then a simple geometry SOP, so you can accumulate the attribute (maybe after promotinig it as detail).
Not sure it's what you're looking for anyway ...
Cheers!
Marco
