hou ui Button Colour
pxptpw
Hello fellow practitioners,
without going into qt , is there a way to colour buttons , slider , backround of an hda , using the hou module ?
and is there a way to output more than one output in an hda , even if you define 2 outputs in an hda it only ouputs 1 ?
thanks in adavance
  • 2 months later...
I am also interested in it... I think this may not be possible without changing the Theme design itself... and will be globa.
i wish there was some extra refinements on the interface (native wise) and also allow us to further customize things like bigger buttonstrips, alignment, etc...
  • 2 weeks later...
Yes, Use output node and set the output index
  • 3 months later...
forgot to answer my post :) , without qt its very fiddly,
the answer is qt designer and pyqt , great comination and works like a charm,
even made a radial dial selector with colours ,
get a copy of qt designer , design your ui here , import that into houdini with pyqt
basically ,
from pySide2 import QtCore, QtWidgets, QtUiTools
ui_file is where the designed .ui frile is which is created fro qt designer
QtUiTools.QUiLoader().load(ui_file, parentWidget=self) and this guy pulls in the ui_file from designer
hope this helps anyone who needs this
Edited by pxptpw
