damighost 0 Posted December 1 Hi guys Ive been struggling to get my head around making similar leaves like the ones in the pictures. Any suggestions? I cant seem to make the leaves 'lay down' similar to how a hair groom would be combed or a feather system would lay the leaves down. Damien leaf_001.obj leaves.hiplc Share this post Link to post Share on other sites
ThomasPara 71 Posted Monday at 02:09 PM leaves_fix.hiplc 1 1 Share this post Link to post Share on other sites
damighost 0 Posted Monday at 02:24 PM Thomas! omg, you are an absolute legend. Thanks so much for this! I am so interested to see how you set up your wrangle and am dissecting it now. I owe you a beer!! Damien Share this post Link to post Share on other sites
AntoineSfx 23 Posted Monday at 06:07 PM *If* you're not too comfortable with the vector math, you can use this simpler wrangle, after setting the normals on the sphere v@up=set(0,1,0); also, you can add a transform on the leaves (rotate x by 90 + some amount) to have the leave slightly rotate away from the sphere. The orientation is totally defined by two vectors (N and up), and you can easily set them explicitly (if you want to point at something), but there are many ways to set the orientation https://www.sidefx.com/docs/houdini/copy/instanceattrs.html Thomas' answer is better if you need more control, or for example if you need to change @orient over time, because quaternions are better at interpolating the orientation in 3d. 1 Share this post Link to post Share on other sites
damighost 0 Posted Monday at 06:15 PM Thanks @AntoineSfx Ive been reading up on that page but was a bit stumped with all the applications to be honest. Thanks for the info, i will try it out as well! I was thinking about the N and up but got confused as how to implement. Its so damn fun. Damien Share this post Link to post Share on other sites
