Pop orient from source geo each frame
marles
Hi folks,
I'm stuck on a issue. I have a deformed geo that i have fractured in packed pieces. Then I want to use a popnetwork to drive my packed pieces. I would like to update the position and the rotation of my particles with the deformed geometry, but when i try to update the position with a pop wrangle like: @P = point(1, "P", @ptnum) with my geo source on the second input of the popnet, the orientation dosent fit of the original geo, the orientation is not updated.
So, how can i update properly (position and orientation) of my packed pieces with the source deformed geo in the popnetwork frame by frame ?
here is some video to show you, ths ! ;)
What i have, orient not updated:
orient.mp4
What i would like, fine deformation:
orientok.mp4
it depends on whether your pieces are only transforming or actually deforming, for deforming ones you'll need to replace the geo every frame
for transforming you could use following (if you also bind input 0 to Myself)
matrix3 xform = primintrinsic(1, "transform", @primnum);
setprimintrinsic(0, "transform", @primnum, xform);
@P = point(1, "P", @ptnum);
you can also just use RBD Packed Object and Bullet Solver to bring your pieces in as Animated Static or Deforming Static Objects which will update them for you
or if your particles don't have packed prims attached, you can store it as orient
matrix3 xform = primintrinsic(1, "transform", @ptnum);
p@orient = quaternion(xform);
it's a bit difficult to guess without a hip file
Hi thomas !
Thanks for your answer, sorry i couldn't share the hip file, but i created a simple scene to show you what i want and my problem.
concerning your solutions :
- Replace the geometry ecevry frame could be a nice solution but i 'm not sure how to do this.
- The geometry is a deformed geometry, not transformed. so the first solution using intrinsect doesn't work beacuase it doesn't take the deformation (orientation etc....).
- Using rbd packed object and bullet solver works well, but i wanted to use pop network beacause i don't need collision bertween pieces and it will be faster to compute with pop solver no ?
Basicaly what i want: i have the deformed fractured geometry, and make it progressively exploded (with a simple noise/pop force), at P.y >5 for exemple. But i want a smooth transition between the popforce and the geometry movement. so the packed pieces need to follow correctly the movement before starting to explode.
here is the hip file woith what i want, what ii try and where i failed
Test_Pop_Orient.hipnc
Thx again for your help, very helpfull !
Hi there,
I would do a frame record in the solver, basically set up a trigger attribute initializes from 0, and in certain condition turn to 1(in your case let's say if(@P.y>5)). And also record which frame it trigger, and name it something like trigger_frame. And no matter you are using rbd or pop, you can manipulate your force/vel/pos when @Frame >= trigger_frame.
You can do this separate in another solver sop or you can directly record in the current dopnet.
This is normally how I would do something like character walking then shattering, basically if @Frame >= trigger_frame, the pieces will falling or exploding etc, if not then copy the intrinsic from the animation.
Here are some info about how to setup trigger attribute and record the trigger_frame.
Maybe there is a better way to do it, but I hope this would help.
Edited by jimeng20
