cluster pieces in voronoifracture (H16) not in later versions
anicg
  • 2 weeks later...
5 hours ago, anicg said:
I need the functionality of the old "Delete Exterior Cluster Edges".
What did it do? Can you give an example? Removing edges from exterior does not make sense.
Anyways groups ("outside" for exterior) are still there and you can use those to get what you want
Edited by JJ FX
  • 6 months later...
You could, for example, extract every piece in a loop, create a group with unshared edges, fuse, then create a second group which could do combine with the first one to isolate the offending edges. Then disolve
________________________________________________________________
Vincent Thomas   (VFX and Art since 1998)
Senior Env artist & Lighting & MattePainter & Creative Concepts
 http://fr.linkedin.com/in/vincentthomas
