How to get All the bgeo.sc used in scene
Hiro11
I want to print all the bgeo.sc used in the scene.Using Python.
hou.fileReferences() doesn`t give me any bgeo.sc used in the scene.
I am looking for a way.
Can someone guide me??
Thanks
Hiro
Edited by Hiro11
I think you would have to recursively scan all nodes in the system for node types that are known to reference files. Look for the File node, and the FileCache node. Once you have those nodes, you can review their .parm value to extract the filename they reference.
  • Thanks 1
AtomicPerception
Alex Rusev
Thanks for the reply.Sorry I was late to see this.
This Worked perfectly!!
files = filter(lambda p: p.endswith('.sc'), [n.evalParm('file') for n in hou.nodeType('Sop/file').instances()])
Thanks
Hiro
import os
import hou
text = '\n'.join(files)
hipdir = os.environ["HIP"]
hipname = hou.hipFile.basename()
name,ext = os.path.splitext(hipname)
file_path = os.path.join(hipdir,(name+'.txt'))
with open(file_path, 'w') as f:
     f.write(text)
It turn out like this.I am a beginner at python stuff,it might be not good.But,it works for now.
Thanks!!
