Else if command
Dumarus
Hi everyone,
I'm building a HDA that will pick the the proper geo at the prims of the proper size, but I need the "else if" statement that is not available in hscript.
What I need is the multiple if command that will output just one true value (there will be one true value actually).
Is it possible w hscript?
Best Regards
Tom
On 18.12.2019 at 9:00 AM, anim said:
it is
    float out = 0;
    if($F>100) out = 3;
    else if($F>50) out = 2;
    else if($F>10) out = 1;
    return out;
however you can always use Python if necessary
Thank you anim. This place is great :-)
I will test it out.
it is
    float out = 0;
    if($F>100) out = 3;
    return out;
Hi Anim.
It is working like charm now.
Thank you a lot :-)
