CopyToPoints variation with changing point count
scorpes
Hi, I would like to know how I can make variation (different objects) using the copytopoints node and changing point counts. I now use the foreach loop with metadata and I use the iteration value to add randomness to a switch node.
Like this tutorial:
But when point counts change, this method doesn't work anymore and all objects are constantly changing over time.
Any idea how to fix this?
copytopoint_var_changingPointcount.hip
That is normal, if you deform or change the surface you are scattering the points onto, it's similar to changing the seed on the scatter. You will get a different result every time the surface changes. Read the help card on the PointDeform node to lock down the point set before you CopyToPoints. There are a lot of example on this forum, try the search bar.
Edited by Atom
You can use this code in your switch. Currently you're using the loop iteration in the switch, but the point/loop order changes as new points come in so it's different each frame. By referencing each point's id attribute when selecting the object it instances you can keep them constant throughout. Hope it this makes sense.
Adjust the max fit value (currently 1) to account for more instance objects
fit01(rand(point("../foreach_begin1/", 0, "id", 0)), 0, 1)
Edited by markingleukc
yes this is what I was looking for, thanks!
1 hour ago, scorpes said:
CopyStamp is the old method..., not compile-able , there is no way to do this with the new method?
whatever Mark said since you are using 17.5
however technically the new method since H18 is using Piece Attribute to copy variants to points and avoiding for loop altogether
Yep and i think it is even faster than compiled for-loops.
