kitsch Posted February 17, 2020 Share Posted February 17, 2020 Hi, I'm trying to advect and resample some lines with a pyro smoke. I import my pyro field with density and velocity(x,y,z) attributes, wich is what i want, and everything works fine, but now i'd like to delete one of the velocity attributes (let's say vel.z), so the lines only get advectec in two axis instead of the three. I've tried the attributedelete node but there's no option for volumes attributes, i also tried to promote the vel.z attribute to some other type so i can delete it, but there's also no option. Maybe i have to bind import it into a VOP and delete it there? I'm in a bit at a loss... Sorry if the question is too dumb, but i couldn't find anything over internet. Thanks! Quote Link to comment Share on other sites More sharing options...
kitsch Posted February 18, 2020 Author Share Posted February 18, 2020 I finally could get it done, in the delete node, in the group name i wrote "@name=vel.y" and it ended up doing what ia wanted :-) Quote Link to comment Share on other sites More sharing options...
kfu Posted February 18, 2020 Share Posted February 18, 2020 (edited) you can set it to zero using volume wrangle,say v@vel.z=0; for example if you want points stop moving at that dimension Edited February 18, 2020 by kfu Quote Link to comment Share on other sites More sharing options...
kitsch Posted February 18, 2020 Author Share Posted February 18, 2020 10 minutes ago, kfu said: you can set it to zero using volume wrangle,say v@vel.z=0; for example if you want points stop moving at that dimension Thanks, i'm still pretty new to vex and didn't think about the volume wrangle! Quote Link to comment Share on other sites More sharing options...
anim Posted February 18, 2020 Share Posted February 18, 2020 If it works by deleting vel.z volume then that may be faster than actually setting the values to 0 Quote Link to comment Share on other sites More sharing options...
Skybar Posted February 18, 2020 Share Posted February 18, 2020 It's worth mentioning that those aren't really attributes, but rather volumes - a type of geometry (usually a box of voxels, voxel = 3d pixel). Thats why you couldn't delete it with an Attribute Delete SOP, and as you found out, you have to delete them in the same way you would delete a polygon for example. Quote Link to comment Share on other sites More sharing options...
kitsch Posted February 18, 2020 Author Share Posted February 18, 2020 10 minutes ago, Skybar said: It's worth mentioning that those aren't really attributes, but rather volumes - a type of geometry (usually a box of voxels, voxel = 3d pixel). Thats why you couldn't delete it with an Attribute Delete SOP, and as you found out, you have to delete them in the same way you would delete a polygon for example. Thanks for the clarification, i knew i had already read it in the cgwiki and it should have been obvious since the AttributeDelete didn't work. Quote Link to comment Share on other sites More sharing options...
