Follyx Posted February 21, 2020 Share Posted February 21, 2020 how could I promote a point attribute via wrangle into a primattribute? Quote Link to comment Share on other sites More sharing options...
Atom Posted February 21, 2020 Share Posted February 21, 2020 Drop down an attribute wrangle that runs over primitives. Fetch the value using the point function and assign it to a new attribute. f@my_promoted_attrib = point(0,"my_point_attrib",0); You may notice the problem with this, however. I am fetching the attribute from point zero. So to do it right, you would have to loop over all the points for a given primitive and then average them to produce a single result. It just make more sense to use the provided attributePromote node. Quote Link to comment Share on other sites More sharing options...
ftaswin Posted February 25, 2020 Share Posted February 25, 2020 (edited) from a point wrangler you can do this : Quote setprimattrib(0, "promoted_prim_attribute_name", @primnum, v@point_attribute, "set"); Instead of "set", you can also put: add,min, minimum,max, maximum,mult, multiply,toggle,append. Edited February 25, 2020 by ftaswin Quote Link to comment Share on other sites More sharing options...
