deform a mesh with pop forces and sopsolver in dop
flcc
As like  some of you i've some time now :), I trying some methods to deform a mesh with pop forces.
I find some simple solutions but  for learning purpose I wanted to try it with a sopsolver in dop.
And yes, i'm definitively not comfortable with the sopsolver. I can't make it work.
I would be happy if someone can take a look.
Deform with particles.hipnc
Edited by flcc
If you drop down a popgrains node in line with you other particle nodes, you can gain a small measure of particle separation. This can get you a few more frames before the particle finally overlap and produce intersecting geometry.
  • Thanks 1
