FLIP Retiming jitter
starion83
Try Retiming  By Speed instead. Keep your input and output ranges equal, but change the speed value. I would Retime from the Suface Cache node, not the Compressed Cache node.
Edited by Atom
depends on the type of the flip sim
for retiming purposes it's easier if you dont use any reseeding or narrow band also make sure to check Add Id Attribute in any case
Edited by anim
