karen Posted May 22, 2020 Share Posted May 22, 2020 After a voronoi fracture, I want some tiny pieces to be merged with and become part of their big neighbours. Any guidance on how to approach it? Quote Link to comment Share on other sites More sharing options...
konstantin magnus Posted May 22, 2020 Share Posted May 22, 2020 Hi Karen, if you are running into problems after, it's mostly wise to solve them before ; ) eg. cluster fracture points or connect some of them by proximity. cluster_fracture.hipnc Quote Link to comment Share on other sites More sharing options...
anicg Posted May 22, 2020 Share Posted May 22, 2020 (edited) is it for rbd or modeling? Edited May 22, 2020 by anicg Quote Link to comment Share on other sites More sharing options...
karen Posted May 22, 2020 Author Share Posted May 22, 2020 it's not for RBD/destruction, and it's just a grid. A grid fractured using voronoi but some pieces are very small. A can remove them using "labs delete_small_parts", but that would create gaps in the grid, I need them to stay and be merged with their neighbours. Quote Link to comment Share on other sites More sharing options...
Noobini Posted May 22, 2020 Share Posted May 22, 2020 well that's simple then, - control size to 'merge' in the blast vu_MeregeSmallFrac.hiplc Quote Link to comment Share on other sites More sharing options...
Noobini Posted May 23, 2020 Share Posted May 23, 2020 (edited) actually, i don't think MY method is quite right ! Edited May 24, 2020 by Noobini Quote Link to comment Share on other sites More sharing options...
konstantin magnus Posted May 23, 2020 Share Posted May 23, 2020 The exact same method also applies for grids.. You define the clustering by the search radius of the connect adjacent node. fracture_cluster.hipnc Quote Link to comment Share on other sites More sharing options...
vinyvince Posted July 27, 2021 Share Posted July 27, 2021 On 23/05/2020 at 1:19 PM, Noobini said: actually, i don't think MY method is quite right ! Probably as you are kind reseeding no ? @Noobini Quote Link to comment Share on other sites More sharing options...
vinyvince Posted July 27, 2021 Share Posted July 27, 2021 On 23/05/2020 at 1:34 PM, konstantin magnus said: The exact same method also applies for grids.. You define the clustering by the search radius of the connect adjacent node. fracture_cluster.hipnc Yeah, you could also put a cluster point before the voronoi , kind of similar idea @konstantin magnus Quote Link to comment Share on other sites More sharing options...
zeyneptopalll Posted December 18, 2021 Share Posted December 18, 2021 You can use rbd cluster node as well Quote Link to comment Share on other sites More sharing options...
