eunchae Posted May 24, 2020 Share Posted May 24, 2020 I grouped the edges and colored them, but that's not what I want. I want the color to enter only the edge I want as shown in the picture 1. And I want to apply this to the shader and use it as a path. What should I do? Thank you. Quote Link to comment Share on other sites More sharing options...
Noobini Posted May 24, 2020 Share Posted May 24, 2020 convert line ? Quote Link to comment Share on other sites More sharing options...
eunchae Posted May 24, 2020 Author Share Posted May 24, 2020 2 hours ago, Noobini said: convert line ? I tried using converline, but still not. (It is difficult to understand the function of the converline.) Could you share your hip file? Thank you. Quote Link to comment Share on other sites More sharing options...
Noobini Posted May 24, 2020 Share Posted May 24, 2020 note that after convertline, prim is an edge. coloredges.hiplc 1 Quote Link to comment Share on other sites More sharing options...
Noobini Posted May 24, 2020 Share Posted May 24, 2020 ehhhhhh...FWIW, i fumbled around with visualising the damn thing coloredges2.hiplc 1 Quote Link to comment Share on other sites More sharing options...
eunchae Posted May 24, 2020 Author Share Posted May 24, 2020 30 minutes ago, Noobini said: ehhhhhh...FWIW, i fumbled around with visualising the damn thing coloredges2.hiplc haha!! WoW !!! It was helpful. Thank you !!! Quote Link to comment Share on other sites More sharing options...
eunchae Posted May 24, 2020 Author Share Posted May 24, 2020 1 hour ago, Noobini said: note that after convertline, prim is an edge. coloredges.hiplc Sorry to ask you again, but maybe .. Is there a good way to select the edge I want? Thank you. Quote Link to comment Share on other sites More sharing options...
Noobini Posted May 24, 2020 Share Posted May 24, 2020 not sure how to answer that, i just selected manually in viewport, shift click edges sequentially... Quote Link to comment Share on other sites More sharing options...
eunchae Posted May 24, 2020 Author Share Posted May 24, 2020 Just now, Noobini said: not sure how to answer that, i just selected manually in viewport, shift click edges sequentially... Ultimately, what I want to do is the edge that I want in geometry to shine. Or ... it's to specify the color. (Like image) I am not sure if my approach is right. Thank you for answer. Quote Link to comment Share on other sites More sharing options...
Noobini Posted May 24, 2020 Share Posted May 24, 2020 i'm not sure if it's possible to edge-colour if your geo hasn't been converted to line...i mean unless you colour the edges that HAVE been converted...then comp in on top of your orig geo render ? Quote Link to comment Share on other sites More sharing options...
Librarian Posted May 24, 2020 Share Posted May 24, 2020 Maybe it Helps ..You can convert Later in your mat(vop) . Just play with that Colors.hipnc 1 Quote Link to comment Share on other sites More sharing options...
eunchae Posted May 24, 2020 Author Share Posted May 24, 2020 14 minutes ago, Noobini said: i'm not sure if it's possible to edge-colour if your geo hasn't been converted to line...i mean unless you colour the edges that HAVE been converted...then comp in on top of your orig geo render ? Um ... I don't understand, but I will render the edge colors individually as paths. And I am trying to give glow effect in comp. Quote Link to comment Share on other sites More sharing options...
eunchae Posted May 24, 2020 Author Share Posted May 24, 2020 7 minutes ago, Librarian said: Maybe it Helps ..You can convert Later in your mat(vop) . Just play with that Colors.hipnc You are very kind. Thank you. Quote Link to comment Share on other sites More sharing options...
Noobini Posted May 24, 2020 Share Posted May 24, 2020 1 minute ago, eunchae said: Um ... I don't understand, but I will render the edge colors individually as paths. And I am trying to give glow effect in comp. well this sounds like you DO understand... Quote Link to comment Share on other sites More sharing options...
eunchae Posted May 24, 2020 Author Share Posted May 24, 2020 3 minutes ago, Noobini said: well this sounds like you DO understand... Oh! That was it. Sorry, I am not good at English. I will refer to your answers. Thanks. Quote Link to comment Share on other sites More sharing options...
