when to use .sim vs .bgeo.sc for simulations
 Sim stores a bunch of simulation objects and their data, so then you can continue to simulate later at a given point, is also way heavier on your HDD. So if you aren't planning in using for initial state or such uses like that I would just use .bgeo which is a compact binary format and lighter on your HDD for everything else.
Edited by Sepu
  • Like 2
most commonly you'd just cache only data you care about to .bgeosc files, because caching to .sim files can be insanely heavy
if you are worrying about crashing or want to continue the sim at later time, you can additionally enable checkpointing to .sim files and specifying Length and maybe Interval, to literally cache a few last .sim files only for the purpose of restoring, while your main cache is still .bgeosc
Edited by anim
