how to import constraint from DOP to SOP
tagosaku
Hi, I am looking for how to import simed constraint object from DOP to SOP, in order to use DOP data (distance, impact attributes, etc, per primitive).  I am guessing we should be able to import constraint data by Dop Import node, but there are something mistakes.
I found another way that he turns on a constraint network node > relationship > ON attach internal constraint object parm, but I want to keep turning off this parameter.
Thanks
image.thumb.png.a22f30e0921d9cc71b3cdb7ec8df839e.pngconst02.thumb.png.29488e8333cca9be9a9368a9cbadd42b.png
Edited by tagosaku
  • 1 year later...
On 03.02.2022 at 4:47 PM, papsphilip said:
unfortunately this method does not bring the animated constraints, they are not moving, i just see my pre-sim constraints with animated attributes, but the primitives are static. Is there a way to bring the deformed constraints back to sops?
