general: attribute reading / setting in any node
Basic question: basically its not possible to set any attribute/parameter in any node. I.E. scatter node, force toal count (npts). There is no way to set this attribute via a i.E. Detail wrangle? Any other ways? Python? Or are some attributes not changeable from outside the node? Is this basically true?
Edited by Follyx
Depends on what you mean exactly. In your example you can create a detail attribute and grab it in the parameter with expression, for example: detail(opinputpath(".", 0), "amount", 0)
That will grab the value of detail attribute called "amount" from the node that is connected in the input.
