emix941 Posted July 1, 2020 Share Posted July 1, 2020 Hi, As known Houdini makes hard tasks easy and easy tasks hard. So at first sight really simple task, but I cannot find a way to overcome it. The bridge that connects hole in ngon looks like it is somehow outer edge of a polygon. Maybe there is a way to some how fuse it or ignore such an inner edge during for example resampling? Fuse bridge that connects hole in ngon.hipnc Quote Link to comment Share on other sites More sharing options...
timoNZ Posted October 17, 2025 Share Posted October 17, 2025 Did you ever find a solution for this? Quote Link to comment Share on other sites More sharing options...
hannes603 Posted October 27, 2025 Share Posted October 27, 2025 odf.hipnc Quote Link to comment Share on other sites More sharing options...
Fenolis Posted November 1, 2025 Share Posted November 1, 2025 Divide with Remove Shared Edges enabled > Resample > Hole > Polyextrude/Labs Thicken All about the order of operations. Quote Link to comment Share on other sites More sharing options...
AntoineSfx Posted November 7, 2025 Share Posted November 7, 2025 On 7/1/2020 at 3:11 PM, emix941 said: Hi, As known Houdini makes hard tasks easy and easy tasks hard. So at first sight really simple task, but I cannot find a way to overcome it. The bridge that connects hole in ngon looks like it is somehow outer edge of a polygon. Maybe there is a way to some how fuse it or ignore such an inner edge during for example resampling? Fuse bridge that connects hole in ngon.hipnc That's very easy. This is because resample doesn't respect the way the vertices are wired for that bridge. Just drop a Hole -> Un-bridge holes before resample Do whatever you want after that, Finally rebuild the hole with Hole SOP If you need the geo for more than the outside look, you also need to make sure that the bridge has shared points, otherwise you're going to have internal faces. Maybe try a fuse for that portion of the geometry, Quote Link to comment Share on other sites More sharing options...
