Jebbel Posted July 14, 2020 Share Posted July 14, 2020 (edited) Hi Everyone, I'm looking to create EXACTLY this effect in de houdini docs: https://www.sidefx.com/docs/houdini/shelf/largeocean.html#using-large-ocean (example vid) I've traced it back to the launch event of H17: (skip to 01:20:00 or so) Ofcourse there's no tutorial or documentation to be found on how to achieve this. Would anyone know how to achieve this? As far as I can tell the Whitewater setup still requires FLIP as input. I've had no sucvces doing this in the popsolver; it just doesn't look right... and I'm a noob much obliged! Edited July 14, 2020 by Jebbel typo Quote Link to comment Share on other sites More sharing options...
dleonhardt Posted July 14, 2020 Share Posted July 14, 2020 The Ocean Foam SOP will do what you are looking for. That particular effect doesn't need a FLIP sim as input. https://www.sidefx.com/docs/houdini/nodes/sop/oceanfoam.html Quote Link to comment Share on other sites More sharing options...
Jebbel Posted July 14, 2020 Author Share Posted July 14, 2020 2 minutes ago, dleonhardt said: The Ocean Foam SOP will do what you are looking for. That particular effect doesn't need a FLIP sim as input. https://www.sidefx.com/docs/houdini/nodes/sop/oceanfoam.html I've noticed this sop indeed... but it's not giving me that spray and mist like in the example. but maybe I need to pull the levers a bit more? Quote Link to comment Share on other sites More sharing options...
Jebbel Posted July 14, 2020 Author Share Posted July 14, 2020 Emitter Particles are created within a specified region based on various emission criteria from the input ocean layers. These particles could then be fed into any custom particle simulation for emission. Solver Foam particles are created according to the various emission criteria then run through a 2-D particle simulation that incorporates the ocean velocity and neighboring particle proximity to give realistic foam behavior. The output of this mode can be used directly for rendering foam with the Ocean Surface shader. This suggests I would need to use the emitter mode as input for POPS... On the launch event they are using the whitewater system with a deformed mesh. this is a unicorn... Quote Link to comment Share on other sites More sharing options...
Jebbel Posted July 15, 2020 Author Share Posted July 15, 2020 found this bit in a different post: In the white water solver, for the "Source Volume" you can use the surface SDF generated from an Ocean Evaluate node (volume tab). In the "Emission Source" you can use any particles converted to a vdb named "emit" and that will work. For instance, you could use the "Ocean Foam" to generate the source particles and merge them with any other particle source that you wish. maybe someone can help me figure this one out? I haven't been able to get this to work. Quote Link to comment Share on other sites More sharing options...
machineyes Posted February 13, 2021 Share Posted February 13, 2021 Hi Jebbel, did you ever figure out how to accomplish this? thanks Quote Link to comment Share on other sites More sharing options...
paranoidx Posted September 9, 2021 Share Posted September 9, 2021 Maybe everybody found it, but still I leave it here for better future search, there is an attribute from the ocean evaluation call `curp` which you can drive for whitewater source or pop network https://www.sidefx.com/docs/houdini/nodes/sop/oceanevaluate.html Cusp Attribute Add a cusp point attribute to the output geometry that represents the sharpness of the wave peaks at any point, with values ranging from below 0 if the wave is stretched out, to greater than 1 if the wave peak is so sharp it has inverted. Cusp Direction Attribute Add a cuspdir vector point attribute to the output geometry that points in the direction of the wave peaks. Visualize Cusp Visualize the cusp attribute by color. Attribute Ramp The color ramp with which to visualize the cusp attribute. 1 Quote Link to comment Share on other sites More sharing options...
HM_2020 Posted February 12, 2022 Share Posted February 12, 2022 On 14/07/2020 at 1:44 PM, Jebbel said: On the launch event they are using the whitewater system with a deformed mesh. this is a unicorn... Any idea how to do this? I would like to take a meshed flip sim and use OceanFoam to create whitewater as if it was using a Spectrum. Cheers! Quote Link to comment Share on other sites More sharing options...
