How to change a deformed object from high poly to low poly.
On 2020. 7. 15. at 5:30 PM, sant0s81 said:
Morning,
somehow I dont understand what you mean since you write "from high poly to low poly" and than "this was done in low poly" and "change to high poly" :)
Could you be a bit more specific?
Cheers
Hi!
 Left: High poly        Right: Low poly
And this is animated.
Simulate an animated low poly. And replaced by high poly...
(low poly -> high poly..)
Do you understand?
Thank you for the reply.
