Vellum hair issue on moving geo
caskal
Hey magicians,
I'm having some issues adding vellum hair to a moving geo. I tried using hair generate, and a for each loop to pin point 0, but for any reason the hairs go crazy.
Simulated mesh also has static points (used point deform), so not sure what is causing this. I also tried scattering points on the animated mesh, but hairgen doesn't work when I select "per point", is this a bug in 18.0.416? I have normals on the points, but nothing appear. I believe I solved similar before using hairgen on scattered points.
I also selected "match animation", when is not selected, hairs fall correctly, but when I try to make follow the moving points, constraints seems to go crazy:
TSrulW8Avu.gif.22ae4693b2ba462293c85428f9862dc6.gif80yJCiPdks.png.5f13ee14b5d2233964d4b0d1ce9f3e72.png1oRlRTFLD9.gif.5134506817fa1ee2a63c8204b145aefb.gif
Any thoughts?
Thanks!
Edited by caskal
  • 2 months later...
