davyd00 Posted September 16, 2020 Share Posted September 16, 2020 Hi guys, I need to do a remesh of a break's ground. The problem that I have, I do remesh but the points change every frame. I need the points in the same place not changing every frame because in this points I instance with quixel all types of flora. Any idea how I do a remesh or something for the ground that the points doesn't change everyframe. The noise of the fracture is very high but this ground is approve. I don't want touch this noise for this. Thank you very much! David. Quote Link to comment Share on other sites More sharing options...
underscoreus Posted September 17, 2020 Share Posted September 17, 2020 I am assuming that the ground is animated somehow then since the remesh is changing every frame? Because if it is not animated then you could probably just slap down a timeshift after the remesh and set it to a static frame number and be done with it. However if I've understood you correctly and the ground is animated then I would suggest using the point deform sop. Place down a timeshift sop with a static frame number and then place down a remesh sop. After this place down a point deform sop and hook it up as follows: Remesh node to input 1, timeshift node to input 2 , finally whatever node is right before the timeshift into input 3. This should give you a stable remesh but let you keep the motion of the ground you already had. If the geometry is being funky you might want to tweak the capture settings in the point deform sop. Hope it helps! Quote Link to comment Share on other sites More sharing options...
davyd00 Posted September 17, 2020 Author Share Posted September 17, 2020 Thank you for your answer. You are right, the ground is animated, I try to do this setup but it doesn't work. I place down after deform sop a scatter, this way I can check the points but every frame it's changing the points. I attach the photos with the nodes and timeshift. is it correct? [url=https://subefotos.com/ver/?fc323d1978e82bab24610c45c8b01e37o.jpg][img=http://thumbs.subefotos.com/fc323d1978e82bab24610c45c8b01e37o.jpg][/url] [url=https://subefotos.com/ver/?7879574505ceeb1ef52f631db9f47477o.jpg][img=http://thumbs.subefotos.com/7879574505ceeb1ef52f631db9f47477o.jpg][/url] Quote Link to comment Share on other sites More sharing options...
davyd00 Posted September 17, 2020 Author Share Posted September 17, 2020 I attach the photos with the nodes and timeshift Quote Link to comment Share on other sites More sharing options...
tamagochy Posted September 17, 2020 Share Posted September 17, 2020 Deform scattered points. Quote Link to comment Share on other sites More sharing options...
eyadorabi Posted October 8, 2020 Share Posted October 8, 2020 On 9/16/2020 at 3:41 PM, davyd00 said: Hi guys, I need to do a remesh of a break's ground. The problem that I have, I do remesh but the points change every frame. I need the points in the same place not changing every frame because in this points I instance with quixel all types of flora. Any idea how I do a remesh or something for the ground that the points doesn't change every frame. The noise of the fracture is very high but this ground is approve. I don't want touch this noise for this. Thank you very much! David. I am just discovering that there has been a change in the Remesh sop in Houdini 18.* before I just used the Remesh rest input and it was stable and does not change every frame (on animated/deformed geo). Now it does not work! Also when using the same exact node, the output is different. Quote Link to comment Share on other sites More sharing options...
