Weathering texture tool
konstantin magnus
A minimalist generator for creating occlusion textures right in COPs.
// INPUT
vector pos_tex = set(X, Y, 0.0);
vector pos_mesh = uvsample(geo_mesh, 'P', 'uv', pos_tex);
vector nml_mesh = uvsample(geo_mesh, 'N', 'uv', pos_tex);
float a = radians(angle);
// OCCLUSION
float occ_sum = 0.0;
for(int i = 0; i < samples; i++){
    vector2 u = rand(pos_tex * i);
    vector dir = sample_direction_cone(nml_mesh, a, u);
    vector pos_ray = pos_mesh + nml_mesh * 1e-3;
    vector dir_ray = dir * range;
    vector pos_hit;
    vector uvw_hit;
    int prim_hit = intersect(geo_mesh, pos_ray, dir_ray, pos_hit, uvw_hit);
    occ_sum += prim_hit == -1;
float occ = occ_sum / float(samples);
// OUTPUT
vector color = vector(occ);
assign(R, G, B, color);
texture_occlusion.hipnc
  • Thanks 2
A texture generator for image based direct lighting.
This example is just using a tonemapped JPG. Though by appending ToneMap Ql the same procedure works with HDRIs, too.
// INPUT
// IMAGE BASED DIRECT LIGHTING
vector clr_sum = 0.0;
    vector pos_hit;
    vector uvw_hit;
    int prim_hit = intersect(geo_sky, pos_ray, dir_ray, pos_hit, uvw_hit);
    vector clr_hit = primuv(geo_sky, 'Cd', prim_hit, uvw_hit);
    clr_sum += clr_hit;
vector clr = clr_sum / float(samples);
// OUTPUT
vector color = vector(clr);
texture_hdri.hipnc
  • Thanks 1
Currently working on a from-scratch texturing procedure that simulates water running down surfaces.
Models shamelessly taken from @animatrix course files.
Starting with projected points, the curves run along a volume until they drop onto the next underlying surfaces using nested while loops.
The watery effect is achieved in COPs where the texture is drawn based on measuring distance from texture positions to these curves.
Alright, enough art, here comes the proof of dripping ^_^ :
You are not weathering it, you are making art Konstantin! :)
I haven't seen much example as obviously Subtance has more than enough but a very nice example of advanced weathing in Houdini which picked my interest few months ago was from Wiek Luijken,
I especially like the rainstreak flow and the realistic procedural rivet placement, something which will make sense to do procedurally in Houdini without too much struggle hopefully. On my list on things to do.
Edited by vinyvince
  • 2 weeks later...
  • 2 weeks later...
  • 1 month later...
  • 3 months later...
  • 6 months later...
On 03/03/2021 at 10:03 PM, konstantin magnus said:
A caustics map generator rendered out in Karma using intersect() and refract().
caustics_map.hiplc
Really love this Konstantin! What is the cuastics/piclc file you're using in LOPS to render it? Is that a file you're saving out of Houdini or is that something else? If I open the file and hit render, i don't get the same results. Just trying to figure out why.
Hey Paul,
I had to save out the caustics texture map because Solaris did not update data live from COPs to LOPs. Set the gamma to 2.2 and save the image as a pic-file.
After you have saved the image, just update the file path in stage/materiallibrary1/principledshader1 under "emission texture" and set the "tint intensity" to something like 4.
  • Thanks 1
  • 1 month later...
On 16/10/2020 at 9:13 PM, konstantin magnus said:
Here is the VEX version of the streaking texture procedure. It's pretty flexible now: Starting curves from uncovered areas to any angle, jumping over gaps, gradually changing target direction, measuring curve length for any point and of course texture mapping.
Model taken from threedscans.com
streaks_VEX_2.hipnc
 Im surprised the result looks accurate while there are lot's of overlapping UV , do you know guys if there is a way with autouvlayout to pack and avoid cross UDIM vertex?
  Im  trying to establish better link with Substance and Houdini , trying to get the best of both worlds.  Basically, if I create and get some asset a look made in substance of a given procedural shader like an edge and scratch procedural wearing material recreat live the mesh dependency map directly in Houdini, without any export, baking in substance, importing back blablabla...
When I link that AO and curvature with an external prebake EXR map it's work (after I have to fix a naming error in the Lab tools) but not when I try to "live" connect. Like shown above
The image plane doesn't seem to be recognized and taken into consideration in the SBSAR processing... Im totally bloked. Image plane are named correctly, single channel as expected by substance..
Ideally at the end, processing every asset with PDG. I haven't a post from you @konstantin magnus about PDG, are you not using it ?
Im joining my hip and test substance file I quickly created.. Maybe it's a limitation of substance archive? It can't only take baked, but I guess if so we should be able to trick it isn'it?
Has Anyone done PDG map baking for all element of a scene and don't mind sharing it by chance ?
Many thanks guys!!:lol:
image.thumb.png.8f972f8b728d8ae3bbbcea4276d80c45.pngimage.thumb.png.bdec7bfabcb63772ad093287f69b6104.png
testhoudini2.sbsar
testhoudini3.sbsar
Substance_automation_vince.hip
Edited by vinyvince
Her's my take. I quickly added few things to your setup, geting more color to our blessed duck.    i tried to fade the leaking .I have not found yet how to only fade the streaks not the all thing in case I want this but I like it :)
________________________________________________________________
Vincent Thomas   (VFX and Art since 1998)
Senior Env and Lighting  artist & Houdini generalist & Creative Concepts
 http://fr.linkedin.com/in/vincentthomas
@konstantin magnus
