Force Directed Graph OpenCL
Librarian
Have Fun..    thanx  + @t_hasegawa   Twitter:wub:
file +read
In second example make attributes like in first ..it works For me
https://github.com/d3/d3-force
https://observablehq.com/@d3/force-directed-tree
ForceDirectedGraph_v002t03(1).hipnc
Edited by Librarian
Yunus :wub:  How to ? Point me to Right Direction when you have Time ....
 If You Have Said A, You Must Also Say B ...
geonode = hou.node('/obj/geo') # geometry
geonode.deleteItems(geonode.children()) #
merge = geonode.createNode("merge") # merge
merge.setPosition(hou.Vector2(1,-2))
# box
nodes = []
posarray = [(0,0),(0,2),(2,2),(2,0)] #
for i in xrange(4):
    nodes.append(geonode.createNode("box")) # box
    nodes[i].setPosition(hou.Vector2(posarray[i]))
    merge.setInput(i,nodes[i])
# box
# posarray
posarray2 = posarray[:]
posarray2.append(posarray2[0])
posarray2.pop(0)
anival = [] #
for i in xrange(4):
    anival.append(
        hou.NetworkAnimValue(
            4.0,
            nodes[i].position(),
            hou.Vector2(posarray2[i])))
ne.setVisibleBounds(hou.BoundingRect(-3,-3,6,3),0.5)
ne.setAdjustments(nodes, anival, auto_remove=True)
# ref) http://www.sidefx.com/docs/houdini/hom/hou/NetworkAnimValue.html
for i in xrange(4):
    nodes[i].setPosition(hou.Vector2(posarray2[i]))
@animatrix When you Have Time Please..
I followed ...here its Code ..I download Again 16.5 Houdini...syntax error   /Don't 'see ....Don't Understand-- Nada ...Maybe Typo
IndentationError: ('unexpected indent', ('Sc', 34, 1, ' for point in wrangle.geometry().points():\n'))
import toolutils
#Ask user to select source geometry
sViewer = toolutils.sceneViewer()
selected_object = sViewer.selectObjects('Select geometry to copy nodes to', allowed_types=("geo",), allow_multisel=0)
source = selected_object[0]
#Create folder in which new animated nodes will be contained
root = hou.node('/obj')
folder = root.createNode('geo', 'Moving_Nodes')
folder.moveToGoodPosition()
# Delete default file node from the new folder
for nodes in folder.children():
    nodes.destroy()
#Find a node with Display Flag on
for child in source.children():
     if child.isDisplayFlagSet() == 1:
          geo = child
#Create a new wrangle node which sets Id and Color point attributes to source geo
wrangle = source.createNode('attribwrangle')
wrangle.parm('snippet').set("""i@id = @ptnum;
@Cd = fit01(@P, 0.5, 1);""")
wrangle.moveToGoodPosition()
wrangle.setInput(0, geo)
wrangle.setDisplayFlag(1)
wrangle.setRenderFlag(1)
# Create a new Null node on for every point and copy X and Y coordinates from P point attribute to every new Null
# Create a new Index parameter on each Null which corresponds to its "parent" point
     node_Xpos = point.attribValue('P')[0]*6
     node_Ypos = point.attribValue('P')[1]*6
     new_node = folder.createNode('null')
     parms = new_node.parmTemplateGroup()
     parms.addParmTemplate(hou.IntParmTemplate("index", "Index", 1))
     new_node.setParmTemplateGroup(parms)
     new_node.parm('index').set(point.attribValue('id'))
     new_node.setPosition((node_Xpos, node_Ypos))
# Create a new Python SOP in the source folder with a code which transfers a position from points to the corresponding Nulls on every frame
python = source.createNode('python')
python.parm('python').set("""node = hou.pwd()
geo = node.geometry()
root = hou.node('/obj/Moving_Nodes')
for point in geo.points():
    node_color= point.attribValue('Cd')
    for child in root.children():
        if child.parm('index').eval() == point.attribValue('id'):
           child.setPosition((node_Xpos, node_Ypos))
           child.setColor(hou.Color(node_color))""")
python.setDisplayFlag(1)
python.setRenderFlag(1)
python.moveToGoodPosition()
python.setInput(0, wrangle)
7 hours ago, Librarian said:
@anim :rolleyes::wub::rolleyes: Thanx It works Yessssss ...OO I have Fun
Yes that happens when you copy paste code and even Sublime seems to mess up indents sometimes especially if you don't edit the code in Python syntax.
But my idea was to model your network using the OpenCL force directed graph, solve it using the OpenCL SOP in the BG, and then copy the positions in animated form :)
