Delete Edges?
patis
I would select the edge you want to delete (or more proceduraly create its own edge group upstream) then use the 'dissolve' node and disable 'remove inline points' and probably disable 'remove unused points' if necessary.
  • Thanks 1
On 17.11.2020 at 10:11 AM, patis said:
Hello, I am creating stair.
i want extrude vertex as pillar like 2nd picture using polyextrude. So now the edge is not needed. I searched edge break way. But could not find...
Anything tips for me? Thank you.:)
you can use convert line sop and split (or blast) sop.
Stair Pillar_01.hipnc
  • Thanks 1
