Rotate By Distance
patis
Thank you! :)
But Sorry, The topic uses a sine wave, and it seems that cannot specify a random value or attenuation distance..
I'm ashamed to say, But I would appreciate it if you could tell me in the project file....
Thank you.
Edited by patis
instead of copying the box and then utilizing connectivity it is much simpler to just create points where you want to place your boxes, then copy them there. you can specify an orient attribute for rotations, or you could also use @N and @up for that. since theres no foreach loops its way faster too (try moving the influence object). also added the functionality to your existing node network for completeness.
RotateByDistanceV3.hipnc
Edited by nuki
  • Thanks 1
Thank you so much sir. Your way is so smart...
Thank you to setup important param for noobs...
Add, I learned a lot of tips in your project! I will enjoy the learning!
I really appeiciate for your kindness :'(
Edited by patis
