Multiple Vellum Copies Deforming High Res Geo [SOLVED]
GlennimusPrime
I have a Vellum setup that is working great, until I change one small parameter...
  • I'm using an initial RBD sim to hover 4 low res objects in a big group in the air.
  • I then turn those objects into Vellum cloth, so I can drop them in a big bouncy pile on the ground.
  • Lastly I deform the 4 low res objects with a Point Deform SOP onto the high res geometry.
This works totally fine when I only scatter one of each object.
The problem quickly appears when I scatter more than one of each object in the initial floating RBD pile.
I sort of understand why this is happening, but I can't get my head around fixing this procedurally.
I think the high res objects can't be moved into the position of the low res geo because (once scattering more than one of each object) there is no longer a name (or class?) to define each and every object independently.
I am stumped in finding a way to fix this sensibly without me having to manually make multiple copies of each object with independent naming. Any ideas would be greatly appreciated!
Scene file attached.
Vellum_Low_To_High_Res_Deform.hip
Edited by GlennimusPrime
hey! the issue is that after copying a variant multiple times the class attribute is not unique anymore. You could pointdeform in a foreach loop, or make class unique and create a high res initial state with corresponding copies. I decided for the latter since the foreach of the initial geo has to be run only once and should be faster. Theres also this thread with a few tips to improve performance.
Vellum_Low_To_High_Res_Deform_nuki.hiplc
Edited by nuki
  • 2 weeks later...
Hi @nuki! Apologies for the late reply, I didn't receive a notification someone had replied here.
I like your way of creating a unique class attribute for each of the low res copies.
I mostly understand what you've done and the reason behind why this wasn't working initially, but I have a couple of questions:
Your for each loop, is it's purpose to make copies of the high res objects and transfer the unique class attribute onto the high res copies? I'm not sure I'm understanding how its doing this, and what the blast is for inside that network.
I am also unfamiliar with the compiled block network. I had a quick read of the help file.. Is this step not 100% necessary, but used to to multithread the for each process, making it faster to compile?
Thanks for your help!
  • 4 months later...
