Randomizing Vellum Instance Objects
zbugni
Hi everyone. I'm trying to create a setup that instances a few models randomly as vellum soft bodies. I want them to spawn four at a time, every twenty or so frames. I'm almost there I think- however my current solution involves using a switch that picks a random model based on time, so I always end up getting sets of four of the same model for every round of instancing. I feel like the solution should be relatively simple, but I don't mind changing my approach significantly if it's necessary.
I've attached a .hip file and an image. As you can see in the picture, there are very obvious groups of objects that formed at the same time:
VellumInstancing.hipnc
  • 4 months later...
  • 2 weeks later...
On 4/30/2021 at 10:21 AM, Xtro said:
Is there any benefit from one method over the other? (doing this in dop vs in sop)
Yeah, I'm using DOPs so I can create instances indefinitely! I don't think that can be done in SOPs
