Mark01 Posted December 3, 2020 Share Posted December 3, 2020 (edited) Hey guys, This should be fairly simple. I have a ball bouncing on a plane, I am finding the contact points but rather than displaying then one at a time as the ball bounces, I need them all together on a frame hold I am transferring the Cd attribute from the ball to the plane to get the contact points. Then we are removing all ground geometry except the contact points if (@Cd.g >= 0) removepoint(0,@ptnum); the contact points appear frame by frame as the ball is bouncing. Any idea how to get them all to display at once? So I guess I need to store the contact point somehow? Edited December 3, 2020 by Mark01 Quote Link to comment Share on other sites More sharing options...
vicvvsh Posted December 3, 2020 Share Posted December 3, 2020 Hi, this example shows you how you can get impact points after simulation with bullet solver. This method you can use with classic animation. Since you already managed to get the points just use solver sop only. dop_import_records.hipnc 1 Quote Link to comment Share on other sites More sharing options...
Mark01 Posted December 3, 2020 Author Share Posted December 3, 2020 Thanks for the reply! i think it's even simpler than what you described. i am just trying to store all the color from the impact points on the ground. I assume this can be done with a sop solver and reading the previous frame but im not sure how? Quote Link to comment Share on other sites More sharing options...
Librarian Posted December 3, 2020 Share Posted December 3, 2020 you can use rest and alpha Quote Link to comment Share on other sites More sharing options...
Mark01 Posted December 3, 2020 Author Share Posted December 3, 2020 2 minutes ago, Librarian said: you can use rest and alpha Hmm, that doesn't seem to work, could you explain Quote Link to comment Share on other sites More sharing options...
Mark01 Posted December 3, 2020 Author Share Posted December 3, 2020 [SOLVED] Bring the attribute transfer into the solver rather before it Quote Link to comment Share on other sites More sharing options...
Librarian Posted December 3, 2020 Share Posted December 3, 2020 @Mark01 Exact what that Link and File Do(Only At Once all) ...Just search this Dude on Vimeo he Posted Files and Hda ---- Chen Zeng --- Quote Link to comment Share on other sites More sharing options...
