Projecting mesh from single point to geometry
nkyms
Hello,
Houdini beginner here, I am looking for a solution to project geometry from a given single point (labelled as the green dot in the diagram, just above the mid point of the sphere) to y=0 to make a semisphere.
The point is to have a flat ground without deformations and changes to the UV projection while a camera is positioned at the given point. So say you had a panoramamic image/video applied to the semisphere, it would look undistorted when viewing from this given point.
Thanks in advance!
Edited by nkyms
Thanks for the reply.
No, the shape is close to what is intended but what I'd like to do is bring the points in towards the middle.
In theory I need each point below y=0 to move towards 0,0,0 (or a given point) until it hits the y axis.
14 minutes ago, animatrix said:
You mean like this?
Then you can just use this inside a Point Wrangle SOP:
if ( @P.y < 0 )
    @P.y = 0;
if ( @P.y < 0 )
    @P.y = 0;
No, let me reword this.
I'd like to move each point below the y-axis towards the middle until it reaches the y axis.
Meaning the points will not come to a single point. And when viewing from the middle point, each point will still be at the same angle.
I'd use the ray node, but this only allows for a vector direction.
Edited by nkyms
27 minutes ago, animatrix said:
Thanks for the help so far.
By bringing the points towards the middle of the initial sphere they should hit the bottom of the semisphere along the x,z plane, sorry I think I confused you by saying y-axis.
The first image you sent is the closest, but the angles of each point viewed from the center are changed. I need each point to be the same angle and projected to the lower base of the semi-circle.
Same result along with greetings from stack overflow:
string cam = chs('camera');
matrix xform_cam = optransform(cam);
vector pos_cam = cracktransform(0,0,0,0,0, xform_cam);
vector pos_plane = {0,0,0};
vector nml_plane = {0,1,0};
vector dir_line = normalize(v@P - pos_cam);
float scale = dot(nml_plane, pos_plane) - dot(nml_plane, pos_cam) / dot(nml_plane, dir_line);
v@P = pos_cam + dir_line * scale;
hemisphere_calc.hipnc
  • Like 2
  • Thanks 1
Thanks for the solution.
This did the trick. I still don't really understand what is happening fully in the expression, but I'll have a shot.
You can also use something like this which is similar to Konstantin's approach:
vector linePlaneIntersection ( vector raypos, raydir, planepos, planedir )
    vector diff = raypos - planepos;
    vector d = dot ( diff, planedir ) / dot ( raydir, planedir );
    return raypos - raydir * d;
if ( @P.y < 0 )
    vector n = normalize ( chv("p") - @P );
    vector p = linePlaneIntersection ( @P, n, 0, { 0, 1, 0 } );
    @P = p;
Depending on the P parameter, the result will change, so make sure to set it to non 0, 0, 0. Otherwise all bottom points will intersect at 0, 0, 0. Here I use 0, 0.3, 0:
Edited by animatrix
  • Thanks 2
if ( @P.y < 0 )
    @P = p;
Thanks, this works well. I'll have a look at your solution too.
Edited by nkyms
