dolexd 2 Posted February 3 (edited) Hello, I am trying to work with OpenCL but as soon I enable them on few nodes, like the gas disturb, gas turbulence, it stops working. I just get a mushroom smoke effect. Does openCL not work on these fields? I have attached some screenshots. The first image is without OpenCL, the second one is with smoke disturb disabled and the third image is with openCL enabled on Smoke disturb. Edited February 3 by dolexd Share this post Link to post Share on other sites
Atom 1,208 Posted February 3 Try switching your OpenGL from GPU to CPU under your Houdini preferences. You may be running out of GPU memory. Share this post Link to post Share on other sites
dolexd 2 Posted February 3 Hey, Thanks for your reply. I switched to CPU and I got this error: OpenCL Exception: Could not create OpenCL device of type (HOUDINI_OCL_DEVICETYPE): CPU on platform vendor (HOUDINI_OCL_VENDOR): Intel(R) Corporation. The built-in CPU driver may not support your CPU (-32) Also, I checked my memory and it seems to be fine. It's not taking up that much memory. 1 hour ago, dolexd said: Hello, I am trying to work with OpenCL but as soon I enable them on few nodes, like the gas disturb, gas turbulence, it stops working. I just get a mushroom smoke effect. Does openCL not work on these fields? I have attached some screenshots. Share this post Link to post Share on other sites
