Spars solver rest position?
pelliaz
Rest isn't in the sparse pyro solver. You'll have to add that yourself.
you can copy the nodes from the non-sparse pyro solver
if you look inside: /obj/geo/dopnet1/pyrosolver1/smokesolver_build2
there is a compute_rest box, and you'll need the advect_rest node too.
You need to create rest/rest2 fields too in the smoke object obviously
hope that helps.
  • Like 2
  • 9 months later...
Hi @bunker,
Where do you insert the compute_rest netbox stuff? I've tried to copy the legacy pyro as closely as possible by wiring it into the FIRST FRAME and gas substep dops. Wired the advect rest into the ADVECTION merge and created rest and rest2 fields in the pyro object. But not having much luck with it.
Edited by garf
  • 2 weeks later...
