fell00 Posted February 25, 2021 Share Posted February 25, 2021 Hi, I'm looking for a solution to this user interface things that happens to me sometimes. When I'm dragging on a vector field in the transform sop, I lose access to the other 2 parameters. In this case it's really bad, it seems that All by transforms are now this way ! For example, in this screen shot, I was dragging the value ladder.. I lost X and Z and only have Y. I have tried clicking on the gear and "Reset Parameter Interface" but it doesn't do anything. Quote Link to comment Share on other sites More sharing options...
Behrendt Posted February 25, 2021 Share Posted February 25, 2021 I think hitting Enter in the Value field works if I tested it correctly just now Quote Link to comment Share on other sites More sharing options...
fell00 Posted February 25, 2021 Author Share Posted February 25, 2021 I restored a previous version of my file. I see what you mean. I hope it's that simple When it happens to me again I'll try to just hit enter and post an update. Thanks for the help Quote Link to comment Share on other sites More sharing options...
fell00 Posted February 25, 2021 Author Share Posted February 25, 2021 Hi, It happened to me again. Pressing Enter on the Value field does nothing. I think it's a bug because, if I click on P over the network to display the parameter pop up window it looks ok, can see all 3. If I copy the nodes to another hip file, they look ok. It only happens sometimes in a dedicated parameters window. Sometimes. Quote Link to comment Share on other sites More sharing options...
danicolaj Posted November 20, 2021 Share Posted November 20, 2021 This is a problem I've had for many years, and even at major studios people never know how to get out of it, everyone hates it when it happens. I think it's a "feature" but criminally undocumented (if it is I can't find any trace of docs). there's a way to get out of that mode but I find it randomly... after a few methodical tries I lose my patience and start clicking keys/buttons almost randomly and lo and behold I'm back to normal - I wish someone would post the right keys to press... Quote Link to comment Share on other sites More sharing options...
nibbla Posted January 8, 2022 Share Posted January 8, 2022 +1 to this! Quote Link to comment Share on other sites More sharing options...
eikonoklastes Posted January 10, 2022 Share Posted January 10, 2022 Click the parameter name/label. Quote Link to comment Share on other sites More sharing options...
wgiuliani Posted December 8, 2023 Share Posted December 8, 2023 Just ran into this same issue- if anyone else has this problem-I fixed it by going into the parameter edit menu (the gear icon)- made the parameter invisible- clicked apply- then made it visibile again- clicked apply- and I got all 3 (xyz) parameters back 3 Quote Link to comment Share on other sites More sharing options...
jason_harmon Posted January 14 Share Posted January 14 Thanks for that invisible off / on tip. Worked for me too. Quote Link to comment Share on other sites More sharing options...
hannes603 Posted January 16 Share Posted January 16 you can just type in for ex a ' $ ' to convert it to a expression... then remove it . fixed Quote Link to comment Share on other sites More sharing options...
