ela1995 Posted March 4, 2021 Share Posted March 4, 2021 I have a grid plane, I divide it by 3. I want to make the 3 plane I just divided separated, and I want to control the space (red) between them. How do I do that? Thanks in advance. Quote Link to comment Share on other sites More sharing options...
anim Posted March 4, 2021 Share Posted March 4, 2021 - append Poly Bevel SOP: adjust Distance, check Output Groups/Edge Fillet Polygons - append Blast SOP: set edgefilletpolys as a group Quote Link to comment Share on other sites More sharing options...
ela1995 Posted March 4, 2021 Author Share Posted March 4, 2021 This is a good method, but as I increase the distance, the polygon don't seems to be equal. Quote Link to comment Share on other sites More sharing options...
kroaton Posted September 1, 2021 Share Posted September 1, 2021 Facet > Make unique points. Exploded View, scale only in the X direction. Quote Link to comment Share on other sites More sharing options...
Sean-R Posted September 2, 2021 Share Posted September 2, 2021 You can also drop a Primitive SOP after a Facet with Unique Points and adjust the scale on the transformation tab Quote Link to comment Share on other sites More sharing options...
wacool Posted September 3, 2021 Share Posted September 3, 2021 In your condition, the pieces cannot be equal. they must decrease simultaneously from opposite sides so that they are equal Cut.hip 1 Quote Link to comment Share on other sites More sharing options...
