archz2 Posted June 10, 2021 Share Posted June 10, 2021 I'm trying to achieve noise based growth in an icosahedron which should look like this. However, instead of growing, my volume begins to shrink instead. Please advise. volume growth question.hip Quote Link to comment Share on other sites More sharing options...
Librarian Posted June 10, 2021 Share Posted June 10, 2021 @archz2 just play with file...try (Vdb Activate and other methods expand reference and other noises)... Curios what you have Watched to make this ????? Play.hiplc Quote Link to comment Share on other sites More sharing options...
archz2 Posted June 11, 2021 Author Share Posted June 11, 2021 17 hours ago, Librarian said: @archz2 just play with file...try (Vdb Activate and other methods expand reference and other noises)... Curios what you have Watched to make this ????? Play.hiplc I'm not getting much growth except for this. I'm watching video 11 Adding Forces To Our Solver from Entagma's Volumes 101 course. I played with noise setting but not something significant I'd get. One more thing. Reducing the voxel size is not improving the quality of the mesh. What is that so? Play (1).hiplc Quote Link to comment Share on other sites More sharing options...
Librarian Posted June 11, 2021 Share Posted June 11, 2021 (edited) PlayGrowth.hiplc @archz2 If you have problems with Paid Tutorials By Entagma which you want to sell BY NTF then try to contact directly Entagma Dudes ...Just TIP Edited June 11, 2021 by Librarian Quote Link to comment Share on other sites More sharing options...
archz2 Posted June 11, 2021 Author Share Posted June 11, 2021 Thanks a lot. I studied the script that you sent me and could only figure out changes in only two places. 1. The bounding box sizes. 2. The graphs. What other changes have you made? I applied the above changes that you did but all I could get was a blank volume in the simulation. Moreover, how to grow the volume uniformly in all directions? 8 hours ago, Librarian said: which you want to sell BY NTF then Sell by NTF? I don't understand. What is NTF? Quote Link to comment Share on other sites More sharing options...
Librarian Posted June 11, 2021 Share Posted June 11, 2021 (edited) 10 hours ago, archz2 said: I'm watching video 11 Adding Forces To Our Solver from Entagma's Volumes 101 course. Please provide original File from Entagma Volumes 101 . @archz2 NFT or NTF same s....t Edited June 11, 2021 by Librarian Quote Link to comment Share on other sites More sharing options...
archz2 Posted June 12, 2021 Author Share Posted June 12, 2021 (edited) I don't have the project files. Otherwise I'd have figured out the method till now. I followed these three videos. The final one is in the one which they've done the majority of growth settings. https://drive.google.com/file/d/18N74Bm9JDYMHubSgYWgQVxFJOAs9mbPq/view?usp=sharing https://drive.google.com/file/d/19E1piUUh4oPyqtiUVuksyQN6v10KW87h/view?usp=sharing https://drive.google.com/file/d/1jz6jHadaIdweX7NH8E0u8xEj3VP-cejf/view?usp=sharing Edited June 12, 2021 by archz2 Quote Link to comment Share on other sites More sharing options...
Librarian Posted June 12, 2021 Share Posted June 12, 2021 Quote Link to comment Share on other sites More sharing options...
archz2 Posted June 12, 2021 Author Share Posted June 12, 2021 Thanks for the links. Really interesting geometry. I can't seem to figure out the one I shared in the original post. How can I grow the volume uniformly in all directions on the icosahedron? Quote Link to comment Share on other sites More sharing options...
flcc Posted June 13, 2021 Share Posted June 13, 2021 When you see something traveling in a single direction, instead of uniformly in all directions, you can be sure that somewhere a value who shoud be a vector is a float. In your file, in the first volume vop (after the vdb activate), the bind export vel is set to float, Should be vector. And the pos input of the curlnoise is connected to density. Should be P. And you probably know it, but in the volume vop in the solver the bind export is connected to the normalize instead of the multiply. volume growth question f.hip 1 Quote Link to comment Share on other sites More sharing options...
archz2 Posted June 14, 2021 Author Share Posted June 14, 2021 (edited) On 6/13/2021 at 6:39 AM, flcc said: When you see something traveling in a single direction, instead of uniformly in all directions, you can be sure that somewhere a value who shoud be a vector is a float. In your file, in the first volume vop (after the vdb activate), the bind export vel is set to float, Should be vector. And the pos input of the curlnoise is connected to density. Should be P. And you probably know it, but in the volume vop in the solver the bind export is connected to the normalize instead of the multiply. volume growth question f.hip Thanks a lot for pointing out my mistakes. Before looking at your reply, I developed the script from scratch twice and it eventually worked in the second attempt . I also accidentally forgot to name the bind as 'vel' of volume vop in accordance with the vdb1. Your script is interesting too. It has a different style of growth. One thing I can't understand is the bind type is still float (which should be vector) in my enclosed file, yet the growth is functioning. Why does the volume still grow fine? I watched the video too. They also have kept it as float. ADDING FORCES_SECOND ATTEMPT - Copy.hip Edited June 14, 2021 by archz2 Quote Link to comment Share on other sites More sharing options...
flcc Posted June 14, 2021 Share Posted June 14, 2021 Yes you right. Actually, it's because the "overide type with input" option is checked. So the output value is still a vector. And so you can ignore my first remark haha ! 1 Quote Link to comment Share on other sites More sharing options...
archz2 Posted June 14, 2021 Author Share Posted June 14, 2021 (edited) Ahh! I see!. Becoming proficient at using Houdini requires eagle eyes seriously! So many details. So many buttons. Edited June 14, 2021 by archz2 1 Quote Link to comment Share on other sites More sharing options...
