Separating objects by colour
How can I select objects by colour and split them into different groups so that in the external render engine, I have different sets of geometry on which I can apply different material (3 in the attached file, currently)
I downloaded the original file from this page.
https://www.tokeru.com/cgwiki/index.php?title=HoudiniVolumes
and made changes in the colour ramp of attribute vop titled 'Cd_ramp_by_sdf_depth'.
However, now I'm getting only one colur.
Vol_worms_curlnoise_v02_edited.hipnc
The minimum and maximum values you were using to fit your ramp weren't a good input range for remapping your SDF values. I exported the sampled values to a temporary attribute ("test") and then used those values as the starting point for remapping. Once you have the color values working, the Partition SOP creates groups like you'd expect.
Vol_worms_curlnoise_v03_toadstorm (1).hipnc
Edited by toadstorm
updated file
I see. Thank you so much!! I'll take a deeper look at the SDF values and the ramp.  One more query. How can I avoid the polywires crashing into each others and turning with noisy joints? Enabling or disabling 'prevent joint buckling' doesn't help.
4 hours ago, Fenolis said:
You can try several methods:
- Fuse points
Where exactly are you suggesting to fuse points in the workflow? I added fuse right after scatter but I'm still getting the same result.
- Measure Curvature and Polycut at tight corners
- Run a loop over the lines before Polywire and use Ray to manage layering
I don't know how to do that. What is the process to do it?
16 hours ago, Librarian said:
@archz2 You have Files on Cg-world Japan section Houdini Tutorials
Houdini Cook Book
Thanks for suggesting this resource. It's an extremely vast.
I reached here on their page listing various chapters in their series of tutorials.
https://cgworld.jp/regular/202107-hcb-114.html#related_Entries
Can you point out to any particular tutorial that covers these two techniques?
Edited by archz2
