Set arrays of attribute values
DeBrumaire
Hi everyone !
I'm struggling with a little problem.
What I have, is a point cloud with an attribute integer "clumpid" (visualized just below). What I want to do, is, for each of the @clumpid values (@clumpid values are from 0 to 5) create an array containing all the points that have the same @clumpid values.
For example, for the points that have the @clumpid value at 3, I want to have an array called for instance " i[]@array_3" containing all the points that have the @clumpid value at 3. If possible, I don't want to use the "foreach loop" SOPs.
I tried a few things but the closest solution I have is this one:
But unfortunately, all the arrays are empty..
Thank you in advance for your replies !! :D
