catchyid Posted November 19, 2021 Share Posted November 19, 2021 Hi, (plz see attached image). I am not sure if these are contour lines or if they can be described procedurally? My goal is to use them to create velocity fields around that character. Note: I don't really care if they rotate clockwise or counter-clockwise, as long as the circles are around the arms cross section, legs cross section...One idea I got now is to use the underlying mesh edges (select whatever I wand and delete the rest!?), are there better ideas that can be applied on any mesh? Tx Quote Link to comment Share on other sites More sharing options...
Librarian Posted November 19, 2021 Share Posted November 19, 2021 One way its BB and with this method you can make any Patterns on anything . Play with the file with Vop-s noises endless possibility..Just One Tip install Q_Lib and check the attribute-builder..Like having Photoshop for 3d patterns that give opportunity for easy modeling and now with new curve tool in Houdini 19 oj oj Sky its the limit .Have Fun @catchyid OnlyODforce.hiplc Quote Link to comment Share on other sites More sharing options...
Aizatulin Posted November 19, 2021 Share Posted November 19, 2021 (edited) Hi, you can use surfdist() function for example to get the distance along the surface to given group, which can be the point on top of the head. Once you have the distance, you can clip the lines. contour_geodist_clip.hipncFetching info... @fixed file ... Edited November 19, 2021 by Aizatulin Quote Link to comment Share on other sites More sharing options...
vinyvince Posted November 19, 2021 Share Posted November 19, 2021 On 11/19/2021 at 12:51 AM, catchyid said: Hi, (plz see attached image). I am not sure if these are contour lines or if they can be described procedurally? My goal is to use them to create velocity fields around that character. Note: I don't really care if they rotate clockwise or counter-clockwise, as long as the circles are around the arms cross section, legs cross section...One idea I got now is to use the underlying mesh edges (select whatever I wand and delete the rest!?), are there better ideas that can be applied on any mesh? Tx Expand There are different ways, you could for example extract the center skeleton and copy some circle along the curves... The curve will follow the orient of the arm and leg members and not stay horizontal.... Geodesic distance is also a good one as suggested by Aizatulin ________________________________________________________________ Vincent Thomas (VFX and Art since 1998) Senior Env and Lighting artist & Houdini generalist & Creative Concepts http://fr.linkedin.com/in/vincentthomas Quote Link to comment Share on other sites More sharing options...
