[SOLVED] Mask by Fresnel?
bentraje
Hi,
Is there like a Mask by Fresnel much the same way as Mask by Attribute?
Basically, like Fresnel in shading but instead on rendering, I want to mask all the sides of the geometry (i.e. result of the Fresnel)?
Is this possible? I understand there is Fresnel node but I can't use it on the SOP context only on the mat context.
Edited by bentraje
vector campos = chv("campos");
vector lgtpos = chv("lgtpos");
float rough = chf("rough");
vector wi = normalize(lgtpos - @P);
vector wo = normalize(campos - @P);
vector h = normalize(wi+wo);
float lambert = max(dot(@N, wi), 0);
float D_GGX_TR(vector N;vector H;float a)
    float a2     = a*a;
    float NdotH  = max(dot(N, H), 0.0);
    float NdotH2 = NdotH*NdotH;
    float nom    = a2;
    float denom  = (NdotH2 * (a2 - 1.0) + 1.0);
    denom        = PI * denom * denom;
    return nom / denom;
float GeometrySchlickGGX(float NdotV; float k)
    float nom   = NdotV;
    float denom = NdotV * (1.0 - k) + k;
    return nom / denom;
float GeometrySmith(vector N; vector V;vector L; float k)
    float NdotV = max(dot(N, V), 0.0);
    float NdotL = max(dot(N, L), 0.0);
    float ggx1 = GeometrySchlickGGX(NdotV, k);
    float ggx2 = GeometrySchlickGGX(NdotL, k);
    return ggx1 * ggx2;
float kdirect(float rough){
    return  pow(rough,2)  / 2.0f ;
vector fresnelSchlick(float cosTheta; vector F0)
    return F0 + (1.0 - F0) * pow(1.0 - cosTheta, 5.0);
vector rough_tex = texture(chs("image"),@uv.x, @uv.y);
vector diff = texture(chs("diff"),@uv.x, @uv.y);
float ggx_tr = D_GGX_TR(@N,h,rough_tex.x );
float ggx_trbase = D_GGX_TR(@N,h,rough );
float k = kdirect(rough_tex.x);
float ggx_smith = GeometrySmith(@N, wo, wi, k);
ggx_smith = max(ggx_smith , 0.0);
//@Cd = diff + ggx_smith * ggx_tr ;
vector fresnelv =  fresnelSchlick(dot(@N,wo), chf("fresnel" ));
@Cd = diff*.2 + ggx_tr* ggx_smith * fresnelv;
maybe someone can explain and make this in Real Scene :wub:@bentraje
Edited by Librarian
You can achieve this by writing this sort of code inside a Primitive Wrangle:
string cam = chs("cam");
float near = 0;
float far = -0.01;
vector pnear = fromNDC ( cam, set ( 0.5, 0.5, near ) );
vector pfar = fromNDC ( cam, set ( 0.5, 0.5, far ) );
vector dir = -normalize ( pfar - pnear );
vector n = normalize ( primuv ( 0, "N", @primnum, 0.5 ) );
if ( dot ( n, dir ) < ch("threshold") )
    i@group_fresnel = 1;
  • Like 4
  • Thanks 1
Thanks for the responses.
@Librarian
I couldn't quite directly use it since I guess the code is for the mat context.
That said I think I get the overall logic. I think its doing Method #2 in the code below.
@animatrix
The code works as expected.
Also just for reference. People from slack group also helped me. Here are the results.
Same goal just different execution.
Method 1 (from bcarmeli)
vector @cdir;
vector @raydir;
matrix camMatrix = optransform(chs("camera"));
//get a matrix with the camera's transforms.
@cdir = cracktransform(0, 0, 0, {0,0,0}, camMatrix);
//extract out the camera position as a vector
@raydir = normalize(@P-@cdir);
//get a vector to project pointo from camera
f@facing_ratio = fit11(dot(@N, @raydir),0,1);
if(@facing_ratio>chf("threshold")){
    @group_mygroup = 1;
Method 2   (from David Torno)
vector cam = getpointbbox_center(1);
//Option 1: Get dir per point
vector dir = normalize(@P - cam);
//Option 2: Get single point centroid
//vector c = getpointbbox_center(0);
//vector dir = normalize(@P - c);
float d = fit11(dot(@N, dir), 0, 1);
if(d > chf("threshold"))i@group_mygroup =1;
Will close this thread now. Thanks for the help!
  • Like 2
