How to have the same Remesh result with a different object position ?
Hello
For a cloth set up I need to have the same remesh (via Remesh SOP node) result of an object on each shot. The object to remesh is the same in all shots, but is Position change. I can not dive in the Remesh node but it seems that while translating an object, is remesh result change.
What I want to achieve is to have the same remesh result for each object base position.
My ideas was to use a rest pose, or find a VEX function that does the same as the Remesh node but I can't figure it out.
Thank you for ur time :)
Quote
Hello
i'm not sure it's what you wanna achieve,hope it helps.
get_same_remeshes_od.hip
Edited by Benyee
