spline orientation after vellum simulation
Hello Guys,
I am looking for a way to fix the orientation on the points after a vellum simulation on a spline. I want to create a rope simulation and afterwards use the sweep node to get some geo around my spline but it turns out there are some weird twists. (check pictures below)
Ill attach the scene file below. (rope_simulation.zip)
any help is highly appreciated.
thank you guys so much in advance.
simulated.thumb.png.63a276eb23fd0f93614e55e9a4f10688.pngweird_spin.thumb.png.d96508b8f4ee36fb2a59fb07f19d29ad.png
rope_simulation.zip
19 hours ago, Benyee said:
thank you guys. In my case the orient along curve + sweep worked but i needed to export geo on alembic into c4d. the more elegant way were exporting a spline and using a spline wrap or sweep inside of c4d but then UVs etc are shifting. Imo its a C4D Problem instead of houdini. It seems like c4d cannot read the orient attribute from a spline.
thank you guys for your help, i highly appreciated
