material variation in KARMA [FIXED]
You can vary color by supplying an animated color attribute to the base_color input of the shader. There is also the mtlxSwitch which can allow you to supply various maps or colors based upon a selector, which can be driven by an animated attribute. mtlxMix can blend two colors based upon an animated bias value.
Edited by Atom
