building from patterns change Pattern with attribute
how can I change the value of string parameter in the building from patterns node with an attribute?
I have an attribute wrangle that set the value of different patterns in the relation of a building I feed in but how can I set the pattern string to the according place?
For example I want school, public, church as buildings and they have already a name and detail attribute building on them so I have a switch it is controlled by attribute wrangle to switch for the right building type so far so good.
But the different buildings can have different patterns how they are build and I want to set this pattern in the building from patterns node.
Alternatively I could set this string to the attr. wrangle channel and set it as relative reference in this pattern node - but how???
Thanks!!!
If I understood you need to read detail attribute and use it in "Pattern" field of Labs, also split "pattern" into two values "BaseWall" and  "Floor01":
detail("../NULL", "pattern_group", 0)
detail("../NULL", "pattern_pattern", 0)
Try to split string with split function or so by symbol "<".
Posted (edited)
the problem is this field does not recognize the expression when I put e.g. @pattern or `detail("../NULL", "pattern", 0)` I would like to set the parameter in the wrangle like this setattrib(0, "detail", "pattern_node", s@pattern, @ptnum);but it does work.
Edited by Dag
9 hours ago, Dag said:
Create a new wrangle with test detail attribute s@test = "name"; and connect before building_from_patterns node;
Check if the field can read this.
Posted (edited)
no it does not see this attribute, when I dive inside the first null on the pattern slot see this attribute but not the node itself.
Edited by Dag
