Coz_y_not Posted April 4, 2023 Share Posted April 4, 2023 in attached hip, most copied instances follow the orientation correctly, while just a few seem to have their own opinion on where they should be facing. why, how to fix that? some_copied_instances_do_not_follow_orientation.hiplc Quote Link to comment Share on other sites More sharing options...
Jesper Rahlff Posted April 4, 2023 Share Posted April 4, 2023 its because you are calculating your normals on the primitives in the normal sop. If you change that to calculate on the points it works correctly Quote Link to comment Share on other sites More sharing options...
Coz_y_not Posted April 6, 2023 Author Share Posted April 6, 2023 On 4/4/2023 at 2:16 PM, Jesper Rahlff said: its because you are calculating your normals on the primitives in the normal sop. If you change that to calculate on the points it works correctly If I change to point normals, the orientation is wrong. Yes they are all pointing in the same direction but it's the wrong direction. Each should conform to the direction where the primitive is facing, just like most copies do in the image in the first post. Quote Link to comment Share on other sites More sharing options...
Librarian Posted April 6, 2023 Share Posted April 6, 2023 (edited) @karen attribute promote- just change to First Match. here its a file with many ex from Asia(regarding those issues) ..you can find on qiita website many files and diff methods and tutorials and other links ..Have Fun newnode.hiplc Edited April 6, 2023 by Librarian Quote Link to comment Share on other sites More sharing options...
Aizatulin Posted April 6, 2023 Share Posted April 6, 2023 You can also use the curve as additional input to set the up vector. The up vector shouldn't be a on same line as the normal. some_copied_instances_do_not_follow_orientation_ctangent.hipnc Quote Link to comment Share on other sites More sharing options...
